How many photons are there in a 1 m long He-Ne laser beam?
The discussion revolves around calculating various properties of a He-Ne laser beam, including its intensity, photon momentum, and photon emission rate. The intensity is determined using the formula I = P/A, resulting in approximately 79.577 W/m². The momentum of each photon is calculated to be about 1.047 x 10^-27 kg·m/s. The laser emits approximately 7.15 x 10^44 photons per second. Clarification is sought regarding whether the 1 m refers to the wavelength or the length of the beam, with guidance provided on calculating the number of photons in a 1 m long beam based on the time light takes to travel that distance.
manaXmizery
A He-Ne laser emits red light of the wave length lambda =632.8 nm with a beam diameter of 2.0 mm and a power output of 1.0 mW. (a) What is the intensity of this laser beam? (b) What is the magnitude of the momentum of each photon? (c) How many photons does this laser emit each second? (d) How many photons are there in the 1 m long laser beam?
I = P/A
N = P/E
P= h/lambda
(a) I = P/A
Hence , I = 0.001 / 4*pi*(0.001) = 79.577 W/m
(b) P = h / lambda = 1.047 *10^-27 kg.m/s
(c) E = h*lambda/c = 1.398 * 10^-48 J
N = P/E = 7.15 * 10^44 photons / second
(d) I am not sure if the 1 m here is referring to the wavelength or the length - can anyone explain it to me ? Thanks in advance.
In (c), you have calculated the amount of photons traversing any perpendicular plane along the propagation direction. Fix a plane somewhere in the beam, in one second there are N (whose value you have calculated) photons going in. Then place a second plane 1 m apart from the first one. With the knowledge of the time needed by a beam of light to travel 1 m distance, you should be able to calculate the amount of photons traversing into the first plane (or equivalently traversing out of the second plane) during the same amount of time. This will be equal to the number of photons contained in a 1 m beam.
