How Many Volts Are Needed for My Motor to Lift 12kg in a Time-Lapse Project?
To lift a 12kg load vertically to a height of 1.3m in 60 minutes, the motor must exert a force of 117N. The user initially calculated power as 325W but confused the variables for time and speed. The correct formula for work done is W = F × d, where F is the force and d is the distance. To find the necessary voltage, the user needs to clarify the power calculation and ensure they are using the correct units for time and speed. Accurate calculations are essential for determining the required voltage for the motor to perform the task effectively.
PC22
I am working on a timelaps project so I need my motor to move very slowley, the motor I am using has a max voltage of 24V and a stall current of 1 Amp
The motor I want to use is on this link:
http://www.dynamicperception.com/EZ-Swap-DC-Motor-p/dp-dcm.htm
This motor will need to lift vertically 117N (12kg) of load to a height of1.3m (1300mm) in 60 mins (3600s) at a constant speed.
I need to find out the work done by the motor and convert it into Volts?
so far I have:
P=W/T
W=117N
T=0.36m/s
So: P=117/0.36 =325W I then times this by the time (3600s) to get the work done 1170000J
Is this correct ?
Can some out tell me how many volts this is ?
Any help would really be appreciated
so far I have:
P=W/T
W=117N
T=0.36m/s
Is this correct ?
That's incorrect.The work done can be found by W=F.d
Why did you write T as m/s?Isn't that the time taken(s)?or is it the constant speed given in the question?
And the W is not the force.Power =Work/time taken.
Care to help me work this out, please?
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
