How much energy is used for lift and for thrust in various aircraft?
The discussion centers on the energy distribution between lift and thrust in various aircraft, specifically seeking average percentages of engine power used for each. Participants clarify that engines produce thrust, while lift is generated by wings, and emphasize the importance of Specific Fuel Consumption (SFC) in calculating energy usage. The conversation also touches on the relationship between thrust-to-weight and lift-to-drag ratios, noting that induced drag decreases as speed increases, making parasitic drag more significant at cruise speeds. Additionally, there is a request for sample values of performance ratios for different aircraft types, highlighting the differences in energy consumption across generations of aircraft. Overall, the need for a comprehensive table comparing energy usage in lift and thrust remains a key focus.
Bararontok
Can somebody post a table of the average lift energy/thrust energy ratios or percentages of various types of aircraft?
lift energy and thrust energy? with units of Joule ? Lift and thrust are forces...
What I am asking for specifically is the percentage of the power/energy expended by the engine to generate lift and the percentage of the power/energy used to generate thrust for various types of aircraft.
I'm afraid that unlike the wing, engines don't generate lift. They only produce thrust.
Now as for the energy, I think that what you need is the Specific Fuel Consumption. Maybe you can find the sfc for various engines on the internet.
Aero_UoP said:
I'm afraid that unlike the wings, engines don't generate lift. They only produce thrust.
Now as for the energy, I think that what you need is the Specific Fuel Concumption. Maybe you can find the sfc for various engines on the internet.
Of course the engine does not directly generate lift. When it propels an airplane forward, the wings move against the wind and generate a constant difference in air pressure where the pressure underneath the wing is higher than the pressure above it. In the case of a helicopter, the rotating rotor blades basically act like a vertically positioned fan that blows air downwards to generate lift. Forcing the wing to move against the wind to generate the difference in air pressure in an airplane or blowing air downwards with rotor blades in a helicopter both require energy from the engines and what I am asking for is an average percentage of the energy used in the process of lifting the aircraft up and the amount used to produce the forward thrust.
This might be the information I need in determining the percentage of energy used by the engine to force the wing to overcome drag and generate a constant pressure difference.
http://en.wikipedia.org/wiki/Lift_to_drag_ratio
The tables show the lift already divided by the drag. Now all I need to do is calculate the percentage of energy that the drag and process of creating a constant pressure difference uses up when the engine produces thrust in the case of an airplane and use the same principle in the lift processes of other types of aircraft in addition to factoring in the thrust-weight, thrust-drag, volumetric and specific power density values of various aircraft configurations and get the average of each aircraft then come up with a table comparing the % energy used to produce thrust and the % energy used to generate lift of various aircraft configurations though it would help if such a table is already available.
6 lines, 1 single sentence. What am I supposed to understand from that? This post is quite incomprehensible to me.
I don't see why l/d ratio isn't already the answer you are looking for...
...minus the already explained caveat that the question is meaningless as worded.
It is the answer I am looking for, I just wanted the values expressed as a percentage of the total power/energy used for lift versus the percentage used for forward thrust.
Aero_UoP said:
Again, from what you say I think that what you need is the sfc of the engine.
http://www.grc.nasa.gov/WWW/k-12/airplane/sfc.html
Yes, I understand now. This value takes into consideration the energy used to overcome drag and the energy required to lift an aircraft of a specific weight to a specific altitude and accelerate it to a specific velocity. Thank you for the information.
The following is a list of links for all of the relevant values:
http://en.wikipedia.org/wiki/Thrust_specific_fuel_consumption
http://en.wikipedia.org/wiki/Thrust-to-weight_ratio
http://adg.stanford.edu/aa241/propulsion/sfc.html
No prob. You're welcome :)
Just a little more:
L/D ratio is a percentage. As far as the engine knows, 100% of the energy/force generated goes to countering drag. But a certain percentage of that drag causes lift (yeah, a little sloppily conceived, but basically right...). That's the L/D ratio.
Also, just so we're clear: there is no energy or power consumed by lift in level flight. The force is perpendicular to the direction of motion. But if you find it useful for some reason, you can still use the SFC times L/D in that way.
Likes 1 person
Well, just to be precise, a certain percentage of the thrust would go to countering gravity (when having a downward component) or to accelerating the aircraft downwards (when having an upward component). This includes situations in which the flight is "level" but due to e.g. a large angle of attack during a slow approach, the aircraft maintains a constant altitude but the thrust has a non-negligible vertical component.
Likes 1 person
I'm sure It's power to weight ratio that he wants... Weight = lift in straight and steady flight. Find the aircraft mass and max thrust and you get a ballpark figure.
If you want to get a more accurate figure you can find the NACA specs and get the coefficient of lift and by using the lift equation, find v when L = mg and this will tell you the velocity required to create lift equal to the aircraft mass. You can then use the thrust equation for to find calculate the required amount of thrust to maintain that velocity. Is that what you wanted?
Cheers,
The Jericho.
Likes 1 person
Cheers,
The Jericho.
Yes, the equations you listed here and the previous set of formulas relating lift and thrust are what I wanted. Thank you for this extra information.
Cheers,
The Jericho.
Additionally, is it also possible to divide the lift by the weight to get a lift-to-weight ratio?
L/W >= 1.0, at least for flying aircraft. If it's the other way, the aircraft won't be flying for long.
Likes 1 person
Thrust to weight has often been used as a simple metric to rate the agility of fighter aircraft. Over the years, this has crept up, from 0.2 for the early jets to over 1.0 for current designs. Of course, the measure is often inflated by the afterburner contribution, which yields great results for airshows, where fuel is not an issue.
Commercial jets usually run around 0.1-0.2, again overstated because take off thrust is only used for a minute or two and cruise thrust is usually only about 20% of that.
Likes 1 person
Commercial jets are usually a bit higher than that - more like 0.2 (for quad engine jets) to 0.3 (twin engine jets) at MTOW, with as high as 0.5 or more possible for some jets when lightly loaded (a 777-200LR at max landing weight has a thrust to weight ratio of 0.47:1, and at operating empty weight (which admittedly includes no fuel) is 0.72:1. In other words, a nearly-empty 777-200LR could climb at an angle close to 45 degrees (though in reality, you'd never see this occur, since aircraft are usually flown with a significant payload, and airliners usually use substantially less than maximum thrust when they are climbing with a light load).
Is there any chance that you're looking for energy consumed due to induced drag (drag related to producing lift) versus energy consumed due to parasitic (drag related to profile, turbulence, friction, ...) drag?
Even for a specific aircraft the ratio of induced drag versus parasitic drag decreases as speed increases, and most powered air craft fly much faster than the ideal best glide ratio speed, which is the speed where ideally induced drag equals parasitic drag (meaning that induced drag is 1/2 of the total drag). At cruise speed, most of the energy is being consumed due to parasitic drag, not due to producing lift (induced drag).
Yes, I would appreciate it if you could post some sample values for T/W, L/W, T/D, & L/D ratios, & parasitic drag, of some good new high performance aircraft and older obsolete aircraft from various generations of aircraft technology that did not perform as well for comparison.
At the high end, the Nimbus 4 family of gliders, with over 80 foot wingspans, the lift to drag ratio (which is the glide ratio) is 60 to 1 at over 60 mph (around 60 knots), which is its intended "cruise" speed since it's meant to be used as a competition cross country glider. There should be data somewhere for best glide ratio on most powered aircraft, since it's nice to know in case of a power failure, but I don't know where to get the data for induced drag / parasitic drag ratios versus speed, for speeds near cruise speeds. However, assuming there is a data point for glide ratio at some speed, then you could use the approximate relationship that induced drag is proportional to 1 / speed^2, and parasitic drag is proportional to speed^2 to get an idea of the ratio. The power consumed during best glide ratio is equal to weight x sink rate (power = force x speed), and you could assume 1/2 of this is induced drag at best glide ratio, so induced drag = the power consumed / speed (the total speed, not just the sink rate).
Likes 1 person
If memory serves, most jetliners have glide ratios around 10:1, usually less for older designs.
Fighters are less good, usually 5 or 6:1, with the Space Shuttle at the low end at about 2:1.
To put that into context, the Shuttle entered final approach at 10,000 ft, about 7 miles from touchdown.
etudiant said:
glide ratio ... Space Shuttle at the low end at about 2:1. To put that into context, the Shuttle entered final approach at 10,000 ft, about 7 miles from touchdown.
So 10,000 feet of altitude and needing to travel 36,960 feet, a 2:1 glide ratio would be a problem here. Wiki lists the space shuttle glide ratio as 4.5:1 at subsonic speeds, 2:1 at supersonic speeds, and 1:1 at hypersonic speeds.
