How Much Force is Needed to Hold a Flagpole Motionless?
  • Thread starter Thread starter thousandsaints
    Torque
The problem involves a man attempting to hold a 7.5 m long, 29 kg flagpole motionless by pulling on a rope attached to the top of the pole. The discussion centers around calculating the force required to maintain equilibrium, considering the torques acting on the pole due to gravity and the man's pull.
  • Participants discuss the calculation of torque from the weight of the flagpole and the force exerted by the man. There are questions about the assumptions made regarding the point of application of gravitational force and the angles used in the calculations.
Some participants have provided guidance on the method of calculating torques and have pointed out potential errors in the original poster's approach. There is an ongoing exploration of the correct application of physics principles, particularly regarding the center of mass and the geometry involved.
Participants note the importance of drawing a free body diagram to visualize the forces and torques acting on the flagpole. There is an acknowledgment of the need to clarify the question being asked and the assumptions made in the calculations.
thousandsaints
I really need help understanding this problem. I'd be really thankful if someone could explain it to me.
A man is attempting to raise a 7.5 m long, 29 kg flagpole that has a hinge at the base by pulling on a rope attached to the top of the pole. The figure of the problem is below as an attachment
With what force does the man have to pull on the rope to hold the pole motionless in this position?
\tau=F*r\bot
Net torque = 0
I tried finding the torque caused the weight of the flagpole, and then the torque caused by the man. From that I tried finding the force which the man exerts. But I can't find the correct answer.
Torque from gravity = w*r\bot =mg*Lcos(\Theta) =(9.81*29)*7.5cos30 = 1848 Nm
Torque from the man = F*r\bot = F*Ltan\Theta = F*7.5tan20 = F*2.73m
The two torque values should equal each other. so...
1848 Nm = F*2.73m
F= 1848 Nm / 2.73
F= 676.8 N
What is the question asking for? You haven't really stated that.
Your general method will work assuming your trying to find equilibrium (i.e. the pole isn't moving).
The problem with the details of your calculation however, is the gravity.
For any uniform (in density) object, you can treat the force of gravity as acting on the center of mass (not the end of the pole which you have done in the equation).
It might help if you draw a free body diagram of the pole, to help visualize the difference in radii.
sorry about that. I edited the post above.
The question is:
Welcome to PF!
thousandsaints said:
Torque from gravity = w*r =mg*Lcos() =(9.81*29)*7.5cos30 = 1848 Nm
Torque from the man = F*r = F*Ltan = F*7.5tan20 = F*2.73m
Hi thousandsaints! Welcome to PF! :smile:
(You haven't said, but I assume you're taking torques about the end of the pole on the ground).
In the first equation, you only need half the length (as lzkelley says)! :rolleyes:
In the second equation, I suspect you've drawn the wrong right-angled triangle … it isn't tan20. :smile:
