How Much Heat Does a Power Plant Transfer to a River Each Second?
A power plant with a power output of 1246 MW operates at 34.8% efficiency, meaning that this output represents a fraction of the total energy input. The remaining 65.2% of energy is released as heat, which is transferred to a nearby river with a flow rate of 1.4 million kg/s. The heat transfer can be calculated using the total energy input and the specific heat capacity of water, factoring in the river's flow rate. The flow rate influences how quickly the river absorbs the heat from the plant. Understanding these relationships is crucial for determining the energy transferred as heat to the river each second.
Runaway
A power plant has a power output of 1246 MW and operates with an efficiency of 34.8 percent. Excess energy is carried away as heat from the plant to a nearby river that has a flow rate of 1.4 * 10^6 kg/s.
How much energy is transferred as heat to the river each second.
Answer in J/s
change in entropy = Q/T
I'm not sure how to set this one up, is 1246 the total output ie the fuel being consumed expels that much and 34.8 percent of that goes to making power, or is 1246 what goes to making power, and the other 65.2 percent goes to the river, and where does the rate of flow of the river come into play?
1246 must be 34.8% of total fuel power. the flow rate of river is associated with how much heat 1 kg of water absorbs in 1 second. but for that we need other data.
I interpreted it as: The power plant has a power output of 1246 MW, which represents 34.8% of the energy put in.
So if the total energy is x, then:
\frac{1246}{x} = \frac{34.8}{100}
And so the amount of energy being released as heat is H = x - 1246.
The flowrate of the river affects how quickly the heat released by the power plant gets absorbed. The quicker the water flow, the quicker we expect the heat to get absorbed. If you use the flowrate of the river (kg/s) along with the specific heat of the water (J/kg*K) and the temperature (K), you will get an answer in J/s.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
