How Much Work Is Done in Adiabatic Compression of Gas?
In a reversible adiabatic compression, a gas with an initial volume of 10^-3 m^3 and pressure of 1 atm is compressed to half its volume, resulting in a pressure increase by a factor of three. The internal energy of the gas is expressed as E=3PV, and using the first law of thermodynamics, it is determined that the work done on the gas during this process is approximately 152 J. The calculations involve determining the initial and final internal energies, leading to a work value of 150 J, which is close to the provided answer due to rounding differences. The discussion confirms that the approach taken is correct, with minor discrepancies attributed to rounding in calculations. The final conclusion is that the work done on the gas during adiabatic compression is effectively around 152 J.
v_pino
When a volume 10^-3 m^3 of a certain gas at a pressure of 1 atm undergoes a reversible adiabatic compression to half its volume, its pressure rises by a factor of three. The internal energy of the gas is given by E=3PV, where P is the pressure and V is the volume. By making use of the first law of thermodynamics, or otherwise, calculate how much work is done on the gas to perform the compression.
Answer: 152 J
(1) I tried writing E=E(V,T) or E=E(P,T).
(2) First law of thermodynamics: dE=dQ+dW
dQ = 0 for reversible process.
I differentiated (1) but had no way of getting T.
Am I on the right track?
Answer: 152 J
Yes. You know that there was no heat input into the gas, because the process is adiabatic. Therefore the change in internal energy of the gas is entirely due to work done on the gas:
dE=dW
Applying this statement, along with the equation given in the problem should be enough to get you to the answer.
I'm getting 150J instead of 152J as given in the answer. I substituted V1 and P1 into equation of E to get E1 and substituted V2 and P2 into equation of E to get E2.
E1 = 300 and E2 = 450.
Subtracting E1 from E2 gives 150J.
That's fine. You're doing the problem correctly. You're just rounding. Thus, the answer you get is rounded. I compute, using the same method:
E1=303.98J E2=455.96J Thus, W~152J
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
