How to apply the Clausius-Clapeyron to geysers
The discussion focuses on applying the Clausius-Clapeyron relation to understand geysers, particularly in determining the heat of water at the bottom of a geyser. The poster has been referencing a YouTube video for guidance but struggles with calculations, specifically in finding the temperature T2 using given pressures and latent heat values. They initially used an incorrect value for latent heat, mistaking it for the latent heat of vaporization instead of the change in enthalpy. Despite inputting various values, the calculated temperature remains close to 100°C, which does not align with expected results. The poster seeks assistance in correcting their approach and calculations.
Elemere
Hi first post so forgive any break in widely accepted conduct,
Currently involved in a physics competition one of the question is to investigate geysers. Time and time again I have stumbled upon reference to Clausius-Clapeyron relation. Probably the best source I have come across is a youtube video and while able to replicate his results of total pressure by using his variables I am still unable to determine the heat of the water at the bottom of the geyser. Below I will paste the youtube video and my math that isn't working.
Thankyou in advance
Arrangement of relation given:
http://file:///C:/Users/ryan/AppData/Local/Temp/msohtmlclip1/01/clip_image002.png
Values given:
P1 = aprox 100000 (atmospheric pressure)
P2 = 113000
Delta Hvap = 2.6*10^6 (latent heat of vaporization H2O)
R = 8.314 (gas constant)
T2 = ?
T1 = 100C (boiling point I assume)
When these values are input into the relation the result is 100.0045 when the video states it should be 103 inputting other values doesn't seem to move T2 far from 100.Youtube vid:
I am so sorry and if someone would tell me how I could take this down I would appreciate it. I assumed Hvap was latent heat of vaporization when really it is change in enthalpy which has a value of 41000 J/mol.
I'm not a student or graduate in Astrophysics.. Wish i were though... I was playing with distances between planets... I found that Mars, Ceres, Jupiter and Saturn have somthing in common... They are in a kind of ratio with another.. They all got a difference about 1,84 to 1,88x the distance from the previous planet, sub-planet. On average 1,845x. I thought this can be coincidential. So i took the big moons of Jupiter and Saturn to do the same thing jupiter; Io, Europa and Ganymede have a...
17K
10K
