Demetrius
A ball is thrown at an angle Θ up to the top of a cliff of height L, from a point a distance L, from the base, as shown in the figure below. Assuming that one of the following quantities is the initial speed required to make the ball hit right at the edge of the cliff, which one is it? (Do not solve problem from scratch, Just check special cases)
Here are the following quantities the answer may be:
\sqrt {\frac {gL} {2(tan(\theta)-1)}} , \frac 1 {cos(\theta)} \sqrt {\frac {gL} {2(tan(\theta) - 1)}} , \frac 1 {cos(\theta)} \sqrt {\frac {gL} {2(tan(\theta) + 1)}} , \sqrt {\frac {gLtan(\theta)} {2(tan(\theta) + 1)}}
I need to determine out of the given expressions, which one is correct for the initial speed. All the given quantities have the correct units and they all behave correctly as g grows and as L grows. The remaining input quantity that needs to be checked is Θ. There are three cases where Θ need to be checked.
Case 1: As Θ → 0 , v → ## C\sqrt {gL} ## where C is a dimensionless number
Case 2: As Θ → ##pi/4## , v → ## C\sqrt {gL} ## where C is a dimensionless number
Case 3: As Θ → ##pi/2## , v → ∞
For case 1, I used dimensionless analysis to determine the expression for v
For case 3, I reasoned that as Θ becomes steeper than the the velocity will need to increase to compensate
For case 2, I made a guess that v should be an expression similar to case 1 however I can not prove/show it. I just believe it needs to be a number
Quantity one does not pass case 3. Quantity 4 does not pass case 1.Quantity 2 does not pass case 2.
So, I chose quantity 3 as my answer.
Is my reasoning for case 2 correct? I cannot prove it. I really just guess. I want to know what will happen as Θ → ## pi/4 ##? And did I chose the wrong quantity?
