How to Calculate Acceleration of a Proton in a Magnetic Field
To calculate the acceleration of a proton in a magnetic field, the key equation is F = q(v × B), where F is the force, q is the charge, v is the velocity, and B is the magnetic field strength. For the first problem, the proton's acceleration can be determined using this equation with the given magnetic field of 0.124 T and speed of 2.3 x 10^7 m/s. The second problem involves finding the speed of a proton moving eastward in Earth's magnetic field, which is 3.23 x 10^-5 T, while considering the acceleration due to gravity. Understanding the right-hand rule and the relationship between force, velocity, and magnetic field is essential for solving these problems. Utilizing the textbook for examples can provide further clarification on these concepts.
tmth
I've got two homework questions I don't really understand. Coming to the end of the year so my teacher is rushing through things and forgetting to give us all the notes we need..
I think I need an equation to solve both of em, but I don't know what. Help/an explanation on how to do the problem is greatly appreciated. ^_^
#1) A proton moves at right angles to a magnetic field of .124 T with a speed of 2.3x10^7 m/s. Find the magnitude of the acceleration of the proton.
#2) A proton moves eastward in the plane of Earth's magnetic equator so that its distance from the ground remains constant. Assume the Earth's magnetic field at the equator is 3.23 x 10^-5 T. The acceleration of gravity is 9.8 m/s^2. What is the speed of the proton?
Have you covered {\vec F} = q {\vec v} \times {\vec B}? That is all that is needed (this equation means that the *direction* is given by the right hand rule and the *magnitude* of the force is the absolute value of the charge times v B sin (theta) where theta is the angle between the velocity vector and the magnetic field. This is all you need.
@_@ Haven't covered that.
Then it is very strange that he expects you to do those problems if you haven't even seen the basic equation needed! I unfortunately don't have the time right now to explain it in details. You shoudl look at your textbook, I am sure they show examples!
Well, the problems come from an online problem set, and my teacher doesn't really look at the specific problems. And it *is* optional, but I want to do it to help my grade...
I got em right, with further help from the textbook. Thank you!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
