How to Calculate Electrical Energy Consumption for 230V / 50Hz / 1Ph Apparatus?
The discussion revolves around calculating the electrical energy consumption for an apparatus specified as 230V / 50Hz / 1Ph. It explores the necessary parameters for such calculations, including voltage, amperage, power factor, and time.
  • Technical explanation, Debate/contested
  • One participant asks how to calculate energy consumption for a 230V / 50Hz / 1Ph apparatus.
  • Another participant asserts that voltage alone does not provide enough information for energy consumption calculations, emphasizing the need for amperage, which should be multiplied by voltage.
  • A subsequent reply suggests including power factor and time as additional factors for calculating energy consumed.
  • One participant acknowledges the need for amperage but expresses curiosity about alternative calculation methods.
  • A suggestion is made to refer to a paper on electric power measurements available on IEEE Xplore, which may provide relevant insights.
  • Another participant proposes working backward from the output work required to determine energy consumption.
Participants generally agree that amperage is necessary for calculating energy consumption, but there is no consensus on whether alternative methods exist or how to approach the calculation comprehensively.
Some assumptions about the apparatus's operation, such as load characteristics and efficiency, are not explicitly stated, which may affect the calculations. The discussion does not resolve how to incorporate power factor or time definitively.
gotlaub
How do I calculate the consumption of energy for an apparatus with these characteristics: 230V / 50Hz / 1Ph ?
You can't. That's just the type of electricity it requires, not the quantity. You need the amperage, which you then multiply by the voltage.
better toss in power factor as well as time as factors if you want energy consumed.
i know that i need the amperage...i thought there's another way to calculate the energy. thanks anyway ;)
What is the Ouptu work to be done? You can work backawrd from that.
  • · Replies 22 ·
17K
  • · Replies 38 ·
  • · Replies 19 ·
  • · Replies 33 ·
