How to Calculate Energy Released in an Aluminum Calorimeter Reaction?
To calculate the energy released in the aluminum calorimeter reaction, the specific heat capacities of water and aluminum are essential. The total mass is 150g, with 100g of water and 50g of aluminum, and the temperature change is from 20°C to 25°C. The energy released can be calculated using the formula q=mcΔT for both substances separately and then summing the results. A proposed method simplifies the calculation by combining the masses and specific heat capacities into one equation, yielding the same result. The discussion emphasizes the importance of clarity in calculations while confirming that both methods arrive at the same energy release value.
hamza2095
There is 100g of water inside of a 50g aluminum calorimeter. After a reaction takes place the temperature of the calorimeter goes from 20 degrees celsius to 25 degrees celsius
Find the energy released by this exothermic reaction
specific heat capacity of water is 4.18 and specific heat capacity of the aluminum calorimeter is 0.91
q=mcT
I approached this question using proportions since the total mass is 150, 1/3rd of the specific heat capacity is that of aluminum and 2/3 is that of water.
q=150g(2(4.18)/3 + 0.91/3)(25-20)
=2317.5J
Is this approach correct?
Why do you complicate things instead of calculating separately heat absorbed by aluminum and heat absorbed by water and then summing it?
Would that not also give the same answer due to bedmas? I thought of doing this but wasn't sure how to
The simplest thing to do:
q=m_{H_2O}c_{H_2O}\Delta T + m_{Al}c_{Al}\Delta T = (m_{H_2O}c_{H_2O} + m_{Al}c_{Al})\Delta T
Thank you! It also gives the same answer as I got but its good to see it in simpler form.
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
