How to Calculate Intensity and Probability for Double Slit and Diffraction?
5 replies · 2K views · last reply
grkm
Diagram of a double slit setup: a photon source on the left fires at a slit barrier with slit width a and separation b, with a screen labelled Detector at distance L, height h and axis x.
Diagram of two parallel rays passing a pair of slits separated by distance d, labelled I and II, with angle theta between the second ray and the dashed line through the lower slit.
slit width = a , slit separation = b = d (at photo),
tanQ=h/L m.λ=b.sinQ
λ.b=sinQ
B=π.d.sinQ/λ
α=π.a.sinQ/λ
Iq=Imx(cosB)^2 x (sinα/α)^2//
My first move was to find intensity but I have no idea about the probability of finding one photon on the detector since It is not a point and It has own length.Should I think the detector as a point ? Location can be relevant with fringes but I'm not sure.
  • Diagram of a double slit experiment: a photon source emits a photon toward a double slit barrier with slit width a, a distance L to a detector labelled d on a screen at x.
Finding the intensity is a good first move. Next, think about how the intensity function I(θ) is related to the probability of a photon ending up in some angular interval between θ1 and θ2 after passing through the slits.
You wouldn't square the intensity. (The intensity, I(θ), already contains the square of the electric field.) When thinking of the probability of where a photon will go, you need to include some interval of angles. For example, if you consider an infinitesimal interval from θ to θ + dθ, then a photon will end up in that interval with a probability that's proportional to I(θ)dθ. For a finite interval from θ1 to θ2, how do you think you would calculate the probability that a photon ends up between θ1 to θ2?
so interval can be taken from h to h+d ? I am not sure but at Imax 's probability is 1/2 I am trying to find on detector.
Well, you'll need to find the angles θ1 and θ2 that correspond to the distances h and h+d.
Sorry, I don't understand this comment.
