How to calculate magnetic flux from voltage?
Magnetic flux density is measured in Teslas or Webers per square meter, and voltage is calculated using Faraday's law of induction, represented by the formula E = -N dφ/dt. The time function in this formula indicates that voltage is induced when there is a change in magnetic flux over time; if there is no movement or change, no voltage is generated. A constant current in a coil produces a steady magnetic field, but without a change in current, there is no induced voltage. The strength of the magnetic field is influenced by the current amount, the number of coil turns, and the core material. Understanding these principles is essential for calculating magnetic flux from voltage effectively.
Nads
I understand that magnetic flux density is measured in Teslas or Weber’s per square meter and that voltage or emf is measured using faraday’s law of induction which is
E= - N dφ/dt
Where
N= number parallel fields
Φ = magnetic flux (Wb)
E= emf (V)
What I don’t understand is the time function of the formula. If we rearranged the formula to make flux the subject what would the time function represent? Correct me if I’m wrong but If there is constant voltage and current through a coil then there is a constant magnetic field inside the coil (or through the core if there is one).
In this situation, what does the time variable represent?
You are confused because of the contradiction in your sentence. If the current in an ideal coil is steady, there is a constant field, and there is no voltage. The voltage across a coil is proportional to the rate of change of current. That is where time comes in.
Likes Nads
Thank you for clarifying that.
So if there is no rate of change in current there is no voltage.
E= - N dφ/dt
Where
E= emf (V)
Hi @Nads
The formula you gave works to find the voltage generated in a coil when their is a magnetic field affecting the coil. If you have a permanent magnet and a coil of wire on a table next to each other and not moving, then there is no voltage induced in the coil. Now if you move one of them there is a voltage induced in the coil - the faster you move them in relation to each other the higher the voltage. That is the time term, dt, in the formula. Also, the more the magnetic field changes, dφ, the higher the voltage.
There is a simulation of this at: https://micro.magnet.fsu.edu/electromag/java/faraday2/
For the second part of your understanding, when a wire, or a coil, has current flowing thru it there is a magnetic field generated. Which end is North or South depends on which direction the current is flowing. If there is AC flowing, the field varies with the AC. In either case, AC or DC, the strength of the field is determined by the amount of current, the number of coil turns, and if there is a core, what material is used for a core.
Cheers,
Tom
Likes Nads
Tom.G said:
Hi @Nads
Cheers,
Tom
Thank you, I found the simulation helpful.
Likes Tom.G
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hello! I want to generate an RF magnetic field at variable frequencies (from 1 to 20 MHz) using this amplifier: https://www.minicircuits.com/WebStore/dashboard.html?model=LZY-22%2B, by passing current through a loop of current (assume the inductive resistance is negligible). How should I proceed in practice? Can i directly connect the loop to the RF amplifier? Should I add a 50 Ohm in series? Thank you!
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
