How to Calculate (mu_s - mu_k) for M1 on a Horizontal Surface?
  • Thread starter Thread starter bulldog23
The problem involves calculating the difference between static and kinetic friction coefficients (mu_s - mu_k) for a mass M1 on a horizontal surface, connected to another mass M2 via a pulley system. The scenario includes varying mass M2 and its effect on the acceleration of M1.
  • Exploratory, Conceptual clarification, Problem interpretation, Assumption checking
  • Participants discuss drawing free body diagrams to analyze forces acting on both masses. There are questions about calculating normal and friction forces, and how these relate to the coefficients of friction. Some participants express uncertainty about the relationship between the forces and the coefficients.
The discussion is ongoing, with participants exploring different aspects of the problem. Some guidance has been offered regarding the relationship between static and kinetic friction and the forces involved, but no consensus has been reached on specific calculations or methods.
Participants note the importance of considering both static and dynamic scenarios in their analysis. There is also a mention of constraints related to the lack of certain information, such as the mass of M1 when at rest.
bulldog23
M1 has a mass of 6.510 kg. It is on a horizontal surface, connected by a light string to a hook. Mass M2 can be increased smoothly by adding masses little at a time.
The pulley has a negligible mass and no friction. When M2 is 3.281 kg it begins to accelerate downwards at a rate of 2.241 m/s2. Calculate (mu_s -mu_ k) for M1 on the surface.
mu_s=(f_s)max/n
mu_k=f_k/n
I really am unsure how to go about this problem. If someone could please guide me through it that would be greatly appreciated!
Draw a free body diagram for each box/crate to see where the forces are acting.
I did that. For M1 there is mg going down, a friction force to the left, normal force upwards, and tension to the right. For M2, there is mg going down, and tension going up.
Right, and you know that mu_s and mu_k are related by the equation F(friction)=mu*(F(normal))
and because this is a frictionless, massless pulley we are able to relate the tensions of the two boxes.
how do you calculate the normal force and friction force?
normal force for M1 should just equal 6.510kg x 2.241 m/s^2, right?
Help...anyone?
No. The mass M1 is not falling through the table, is it? What force is keeping that from happening?
See we cannot give you the answers.
But we can surely help you.
Now you will have to consider two cases.
1) Where the block is on the verge on accelerating.
2) When it starts accelerating.
You will have to consider the frictional forces, tension in the string and the weights of the blocks and of course muk and mus.
I'm studying for my final and I'm having trouble solving this as well...here is my work:
T_1 - u_s(m_1)g = m_1(a) = 0 (This equals zero because a = 0 when static)
T_2 = m_2(g)
T_1 = T_2
so
m_2(g) - u_s(m_1)g = 0
and static friction is:
f_s = u_s(m_?)(g)
I'm not given the m_1 when the object is at rest so how could I calculate both m_1 and u_s?
Ok...why is u_s= m_2/m_1
  • · Replies 24 ·
  • · Replies 45 ·
24K
