How to calculate output of a motor used as a generator
To calculate a motor's output when used as a generator, one can generally assume that a permanent magnet motor will produce a voltage equivalent to the voltage it consumes when spun at the same RPM. For a small DC motor operating at 1.5 volts and 100 RPM, it is reasonable to expect it to generate approximately 1.5 volts when manually spun at that speed. The discussion confirms that this type of inquiry is appropriate for the forum. Understanding the specifications and load conditions of the motor is crucial for accurate calculations. Overall, users are encouraged to explore motor capabilities without needing to purchase each one.
phatlosz
Does anyone know how to figure out how to calculate a motor's output when used as a generator based on the manufacturer's specs for its operation?
ie. Small, but powerful DC motor. 0.40" x 0.32" x 0.66" long. Operates on 1.5 - 3.6 Vdc. 110mA @ 3Vdc, no load. 500mA with load.
http://www.allelectronics.com/make-a-store/item/DCM-299/1.5-3.6-VDC-MOTOR/1.html"
I'm trying to figure out what various motors are capable of without having to buy all of them.
Thanks!
Did I post this in the right forum, or should I have posted it in another category?
Could I assume that if it the motor were spinning 100 RPM and consumed 1.5 Volts, that it would produce 1.5 Volts if I were spinning it at manually at 100 RPM?
Thanks.
Thanks.
Yes. Assuming it is a permanent magnet motor, which yours appears to be.
And yes, I believe this is the correct forum to post this type question.
Thanks for getting back to me... :smile:
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
