How to calculate price of artificial oil
  • Thread starter Thread starter Tiger Blood
    Oil
The discussion centers on calculating the price of artificial gasoline produced from CO2 and hydrogen, with skepticism about its economic viability. The process is noted to be costly, particularly due to the high expenses associated with capturing CO2 from the air, which could be significantly more than capturing it from fossil fuel emissions. Previous discussions indicate that fuel cell cars using hydrogen from electrolysis are already not economical, and this new method may be even less feasible. There is a call for published engineering calculations to verify the claims made about the fuel's cost and efficiency. Overall, the consensus suggests that the proposed artificial gasoline may not be a practical or cost-effective alternative to traditional fuels.
Tiger Blood
I was watching this video about a company that has a device which sucks CO2 out of air, mixes carbon with hydrogen from water and makes fuel for cars
They say that it can power cars even better that gasoline you get from crude oil and that it costs the same, but is there a way I can do some calculations to get some approximate price of that artificial gasoline?
Thread closed temporarily for Moderation...
That video is a substandard reference for PF, but your question is a good one so I'll allow it.
The topic is not free energy. It is a fuel obtained at a cost. Please confine answers to the cost.
Edit: it would be most helpful if someone can find a published paper including engineering calculations for that claimed fuel.
Likes berkeman
See previous PF threads on related topics.
https://www.physicsforums.com/threads/is-this-another-hydrogen-vehicle-scam.940158/#post-5944468
https://www.physicsforums.com/threads/water-as-a-fuel-in-cars.144105/
https://www.physicsforums.com/threads/water-for-fuel.745406/#post-4701066
https://www.physicsforums.com/threads/water-power-in-a-slightly-different-sense.731465/#post-4621858
The general conclusion is that fuel cell cars powered by O2 from air plus H from electrolysis is not economical.
This scheme adds to that by substituting CO2 for the O2. I found this reference: https://www.forbes.com/sites/energy...-for-reducing-u-s-co2-emissions/#4258438c6482 that puts the cost for CO2 capture from fossil power plant exhausts at about $50/MWh. Capturing it from the air would be 100x (?) more expensive. So this scheme is far more expensive than a simpler scheme which itself is uneconomical.
It would be great to see a paper published by the claimants so that we could check their calculations. I suspect that they make it sound good by assigning a wildly inflated value to avoiding more CO2 in the atmosphere. But that's just speculation because we can't see the source.
Likes berkeman
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
