How to Calculate Relative Velocity in Wind for a Plane and Cyclist?
The discussion revolves around calculating relative velocity in the context of an aircraft flying in wind and a cyclist experiencing wind. The problem involves determining the course set by the pilot and the true wind speed and direction affecting both the aircraft and the cyclist.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the need to draw vector diagrams to visualize the relationships between the aircraft's speed, wind speed, and direction. Questions arise about how to represent these vectors accurately and what the implications of "direction in still air" mean.
Some participants are seeking clarification on how to create vector diagrams and the significance of the aircraft's direction in still air. There is an exchange of ideas regarding the setup of the problem and the relationships between the various vectors involved, but no consensus has been reached on a specific method or solution.
Participants note the importance of understanding the vector relationships and the definitions of terms such as "still air" and "true wind speed." There is an acknowledgment that the problem involves trigonometric concepts and vector addition, but specific details remain under discussion.
Zoheb Imran
a,The Speed Of an aircraft in still air is 300 km/h.
In a wind of speed 140 km/h, blowing from a bearing of 230, the aircraft flies due east. Find
i, the course set by the pilot
ii, the time taken for the aircraft to travel 100 km.
b,To a cyclist traveling due east at 18 km/h the wind appears to be blowing at 12 km/h from a bearing of 150. Find the true wind-speed and the direction from which the wind is blowing.
Where's your attempt at a solution?
how to draw a vector diagram ?? of the above problem?? I only have problem in that...
its all simple trigonometry ... after that... i need to know what will be the direction of Aircraft in still air? what does that mean? what will be the direction of of wind... how will we create a vector diagram...of it?
You should be able to draw 3 vectors, where one of them is the final speed and direction of the moving object(which you can find by vector addition).
Hi Zoheb! :smile:
Give them letters!
Call the plane P, the air A, and the ground G.
Then P - A = 300, and A - G = 140 @ 230º.
And you know that P - G is 90º.
Draw a triangle with an arrow on each side, so that the arrow along P - A goes the same way as the arrow along A - G (in other words, it doesn't meet it head-on).
Does that make sense? :smile:
Zoheb Imran said:
… what will be the direction of Aircraft in still air?
Not relevant … in still air, it would go at 300 in any direction … they're simply telling you how powerful the aircraft is.
  • · Replies 26 ·
