How to Calculate the Area Bounded by y = 2 and y = sec²(3x)?
  • Context: MHB
  • Thread starter Thread starter shamieh
    Confused
The discussion revolves around calculating the area bounded by the line \(y = 2\) and the graph of \(y = \sec^2(3x)\) within the interval \(-\frac{\pi}{6} < x < \frac{\pi}{6}\). Participants express confusion regarding the setup of the integral and the implications of the function's behavior within the specified limits.
  • Exploratory, Technical explanation, Debate/contested, Mathematical reasoning
  • One participant expresses confusion about the integral setup, specifically questioning the behavior of \(\tan(\frac{\pi}{2})\) and its implications for the area calculation.
  • Another participant suggests that the limits of integration should be verified against the plot of the functions involved.
  • Some participants propose that the area calculation may need to consider additional regions within the specified interval, indicating potential misunderstandings about the problem's requirements.
  • There is a reiteration of the interpretation that the area should be calculated for one period of the trigonometric function and the line \(y=2\), but this interpretation is not universally accepted.
Participants do not reach a consensus on the correct limits of integration or the interpretation of the problem. Multiple competing views remain regarding how to approach the area calculation.
Some participants note the potential for confusion due to the behavior of the secant function and its implications for the area calculation, as well as the need to clarify the regions to be considered within the specified interval.
shamieh
Sketch the region bounded by the line y = 2 and the graph of $$y = sec^2(3x)$$ for $$ \frac{-\pi}{6} < x < \frac{\pi}{6}$$
Very very confused on this problem...
So here is what I set up..
Top function - bottom function
$$\int ^{\pi/6}_{-\pi/6} 2 - \sec^2(3x) dx$$
so I split the integrals in two.
for the first integral, i let u = 3x , du/3 = dx
thus:
$$1/3 \int ^{\pi/6}_{-\pi/6} sec^2(u) du$$
which = $$1/3tan(u)$$ ... Updating the limits $$|^{\pi/2} _ 0$$
here is where I am running into a problem... $$tan(\pi/2)$$ doesn't exist it is infinity or undefined but I'm bounded by y = 2...So why am i running into this problem? If i am bounded then won't i still end up with 2 - infinity? I am confused. Maybe I'm approaching this the wrong way.
You are asked to find the bounded region, and your limits are within the given interval:
You should be able to show your limits are as given in the plot...
Are you sure they're not also asking for the area of the regions contained where $\displaystyle \begin{align*} -\frac{\pi}{6} \leq x \leq -\frac{\pi}{12} \end{align*}$ and $\displaystyle \begin{align*} \frac{\pi}{12} \leq x \leq \frac{\pi}{6} \end{align*}$ too Mark?
I took the restriction $$-\frac{\pi}{6}<x<\frac{\pi}{6}$$ to restrict the problem to one period of the trig. function. :D
Sorry I'm not following...Are you saying my limits are incorrect - or that I'm integrating the incorrect way?
The way I interpreted the problem is that you are to consider the plot of:
$$f(x)=\sec^2(3x)$$
restricted to the interval:
$$\left(-\frac{\pi}{6},\frac{\pi}{6}\right)$$
And then, you are to find the area bounded by this one period of the trigonometric function and the line $y=2$.
$$f(x)=\sec^2(3x)$$
Oh. I think i see now
  • · Replies 29 ·
