How to Calculate the Total Resistance in a Circuit?
  • Thread starter Thread starter [KNIGHT]
    Resistance
The discussion revolves around calculating the total resistance in two electrical circuits, focusing on the principles of series and parallel resistor combinations.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss identifying pairs of resistors in series or parallel and simplifying the circuits step by step. Questions arise about specific connections and methods used to calculate total resistance.
Participants have offered guidance on identifying resistor combinations and checking calculations. There is ongoing exploration of methods for both circuits, with some participants sharing their approaches and seeking validation of their results.
Some participants express confusion regarding the connections in the first circuit and the assumptions made about resistor configurations. There are references to specific resistance values in the circuit diagrams that are not provided in the discussion.
[KNIGHT]
Calculate the total resistance of the 2 circuits given below
R = R1+R2+R3...
(1/R) = (1/R1) + (1/R2) + (1/R3) + ....
I am unable to understand how to obtain the final resistance
General strategy: Look for pairs of resistors that are purely in parallel or in series. Then replace those pairs with their equivalent resistance. Then do it again, until you've simplified it enough.
After following what you said i got 25/84 Ohms as the answer for the 2nd circuit. Is it correct?
But the 1st one is still confusing because of the connection in between
R = R1+R2+R3...
Answer to Circuit # 2
Rt = R1 * R2 / R1 + R2
Give arbitrary values to each resistance, for example 100 Ohms each. Find a parallel pair and evaluate:Example 2 parallel resistor [Items 1 & 2] 100 Ohms each equals 50 Ohms, that is 100 Ohms divided by 2 resistors. Now add that value to the next resistor in series [ Item 4], you now have 150 Ohms. Find the series branch and add the resistance which equal 200 Ohms Item 7 & 5]. You now have 150 Ohms in parallel with 200 Ohms, evaluate them both in parallel and you arrived at a value of 85.714 Ohms for the entire circuit. Follow the same procedure for circuit # 1
It looks like you've forgotten to take a reciprocal somewhere. Check your work, or better yet, post it here so others can check.
Can you identify any candidates for parallel or serial connections?
Thanks for pointing it out. I have made a simplification error. So the answer is 84/25 Ohms. Is it correct now?
Can i consider 3 & 2 as the 1st pair of parallel resistors and 6 & 7 as the 2nd pair of parallel resistors.
Thereafter should i add the 1st and 2nd pair in series?
Btw its the resistance values that are marked in the diagram
Yes, the result is correct. I cannot comment on your methodology since you did not show it.
Here is the way i did it
considered 1 & 2 as a parallel pair and found their resistance and added it in series with 4. (group 1)
Then i added 7 & 5 in series and considered it as group 2.
The final answer was obtained by adding group 1 and 2 in parallel
Yes, that is a correct method.
What about the method to solve the 1st first? Is it correct?
You'll have to be more explicit.
Any correct method should arrive at the same result...
Yes. Assuming that this was your method for the 1st circuit:
That is a good approach.
  • · Replies 23 ·
  • · Replies 19 ·
