How to Calculate Work and Heat Transfer in a Polytropic Process of Nitrogen?
ZLing
Nitrogen at 100°C and 600 kPa expands in such a way it can be approximated by a polytropic process with n=1.2. Calculate the work and the heat transfer if the final pressure is 100 kPa.
I used the equation T2/T1=(P2/P1)^[(n-1)/n] to find T2. Then i used W=nCv(T1-T2) to calculate work done. Is this correct? But i don't know how to calculate the heat transfer.
No. This is not the work. This is the change in internal energy. To get the work, you need to integrate PdV.
If you know the change in internal energy and the work, then you can use the first law to get the heat.
Chet
Chet
Hi, does that mean I have to find V1 and V2 first?
That's one way to start.
Chet
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
