How to compute the magnitude of a initial velocity u
To compute the initial velocity of a rock thrown horizontally from a tower, the motion in both x and y directions must be analyzed. The rock hits the ground after 3.5 seconds, and using the formula for vertical motion under gravity, the vertical distance was calculated to be 60 meters. The horizontal distance was found to be 50.34 meters, but to determine the initial speed, the horizontal distance must be divided by the time. This led to the correct initial speed of 14.38 m/s. The discussion emphasized the importance of using the correct method to find speed by dividing distance by time.
javii
A rock is thrown horizontally from a tower point A, and hits the ground 3.5 s later at point B. A line from A to B makes an angle of 50 degrees with the horizontal.
Compute the magnitude of a initial velocity u of the rock.
I started looking at the motion in x direction, which is
u the unknown.
Then i looked at the motion in y direction:
And here we have the gravity.
so i used the formula:
s=1/2 * g * t^2
1/2*9.81*(3.5)^2 =60 m/s^2
from trigonometry
tan(50)=60/x
solving x i get 50.34 meters
But I'm not sure if I have done it corretly.
Thank you for your help.
The units should be meters. Other than that, so far you are on the right track, but you have not answered the question yet. You found where the rock lands horizontally, but you are asked to find its initial speed.
Likes javii
javii said:
1/2*9.81*(3.5)^2 =60 m/s^2**m**
That's right. But you need to find the x component of the velocity.
aha, so I have to times the denominator with the time (3.5):
tan(50)=60/x*3.5
Then I will get
14.38 m/s
It that true?
That is the correct answer. However it is more conventional to divide (untimes) the distance by the time to get the speed. :smile:
Likes javii
haha, i will remember that for next time :) Thank you for your time. :)
