How to Design a High-Frequency Air Core Transformer for Low Power Applications?
To design a high-frequency air core transformer for low power applications using PCB conductors, specific details are crucial, such as the operating frequency, signal power requirements, and circuit impedances. Participants in the discussion emphasize the need for more information to provide effective assistance. Suggestions for resources like application notes or software tools are sought to aid in the design process. Providing comprehensive specifications will enhance the chances of receiving relevant advice. Clear communication of requirements is essential for successful collaboration in transformer design.
Eli Hait
Hi,
I need to design a high-frequency, low power air core transformer implemented by conductors printed on PCB.
Does anyone know about an application notes, free software or java applet which cam assist me in this case?
Thanx in advance
despair_eli
:cry:
:cry:
In order for anyone to help out . . . you need to provide a lot more information that you did.
What is the frequency involved?
How much signal/power you need to transmitt?
What are the impedances of your circuits?
Oleh
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
