How to determine what electric motor to use. Need guidance please.
An engineering student is seeking guidance on selecting an electric motor for a UAV project focused on surveillance in Greenland, emphasizing the need for cost-effective and lightweight propulsion systems. The student is specifically looking for resources that explain the mathematics behind electric motors, including range equations, thrust calculations, and battery compatibility. A forum member questions the assumption that electric motors are cheaper and lighter than petrol engines, indicating a need for further exploration of these factors. The discussion highlights the importance of understanding the technical specifications and performance metrics of electric propulsion systems. Overall, the conversation underscores the complexities involved in transitioning from petrol to electric propulsion in UAV design.
SilentIdea
Hello all!
I'm an engineering student who is taking part in a group project to design and build a UAV to carry out surveillance in Greenland. Now my specific task is to sort out our means of propulsion and materials. The problem is up to now I have only learned about petrol propulsion systems in terms of maths.
We are aiming to use an electric motor due to several limitations such as cost and weight. I was therefore wondering if someone could link me to some material which explains the mathematics that need to be attempted in order to work out for example:-
The range equation for an electric motor.
Thrust that can be provided.
How to tell whether or not a battery will be compatible with a certain electric motor. Etc...
SilentIdea
What makes you think electric motors are cheaper and lighter than petrol engines?
I've sent you a PM.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
