How to differentiate a term with respect to metric
the_doors
for example: ##\frac{\partial(F^{ab}F_{ab})}{ \partial g^{ab}} ## where F_{ab} is electromagnetic tensor.
or ##\frac{\partial N_{a}}{\partial g^{ab}}## where ##N_{a}(x^{b}) ## is a vector field.
i saw people write ##F^{ab}F_{ab}## as ## g^{ca}g^{db}F_{cd} F_{ab}## and say we write the term in a way that exposes the dependence on the metric. but exactly what it means ?
You need to write your function in terms of the variables you have, in your case ##g^{ab}## and ##F_{ab}##. The contravariant ##F^{ab}## is not independent of those and so will have non zero partial derivatives wrt both. Writing it in terms of your variables let's you differentiate easier.
As a similar example: Take ##f(x,y) = xy##. The partial derivative ##\partial_yf## is simply ##\partial_y (xy) = x##. This is essentially the same. Do not be confused by the fact that you use the same letter to denote the covariant and contravariant tensors.
for example if ##N_{\mu}(x^\nu)## be unit time like dynamical four velocity, what's happening ? i don't know explicit form of ##N_{\mu}##.
ok we can write for first example:##\frac {\partial (g^{ca}g^{db}F_{cd}F_{ab})}{\partial g^{ef}}## = ##\frac{\partial g^{ca}}{\partial g^{ef}}g^{db}F_{cd}F_{ab}+\frac{\partial g^{db}}{\partial g^{ef}}g^{ca}F_{cd}F_{ab}+\frac{\partial F_{cd}}{\partial g^{ef}}g^{ca}g^{db}F_{ab}+\frac{\partial F_{ab}}{\partial g^{ef}}g^{ca}g^{db}F_{cd}## . is it correct ?
##\frac{\partial g^{ca}}{\partial g^{ef}}=\delta^c_{e} \delta^a_{f}## is it correct ?
what's happening for ## \frac{\partial F_{cd}}{\partial g^{ef}}## ?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
