How Do You Calculate Chemical Reaction Yields?
  • Thread starter Thread starter skyblueff0
    Chemistry Homework
The discussion focuses on solving four chemistry problems related to stoichiometry and mass calculations. The first problem involves determining the mass of lithium hydroxide produced from the reaction of lithium nitride with water, requiring the calculation of moles and molecular weight. The second problem asks for the mass of hydrogen peroxide needed to produce a specific amount of water, emphasizing the importance of understanding the reaction and balancing the equation. The third problem involves calculating the mass of benzene needed to generate a certain volume of carbon dioxide gas at standard temperature and pressure (STP), highlighting the use of reaction ratios and gas volume conversions. The final problem pertains to finding the mass of sodium nitrate produced from the reaction of nickel(II) nitrate with sodium hydroxide, again focusing on stoichiometric calculations. Key tips include remembering conversion methods between grams, moles, and liters, and the significance of balancing chemical equations before performing calculations.
skyblueff0
okay I am going to give you like 4 problems out of like 22 i need to do for homework before the breaks is over can someone just tell me what formula to use, or it would be even better if someone can show me
" "- subscript numbers
1. Determine the mass of lithium hydroxide produced when 0.38g of lithium nitride reacts with water according to the following equation: Li"3"N + 3H"2"O --> NH"3" + 3LiOH
2.What mass of hydrogen peroxide (H"2"O"2") must decompose to produce 0.77g of water?
3.Find the mass of benzene (C(6)H(6)) required to produce 2.66 L of carbon dioxide gas at STP from the reaction described by the following equation : 2C"6"H"6" + 15O"2" --> 6H"2"O + 12CO"2"
4.Determine the mass of sodium nitrate produced when 0.73g of
nickel(II) nitrate reacts with sodium hydroxide according to the following equation: Ni(NO"3")"2" + 2NaOh --> Ni(OH)"2" + 2NaNO"3"
Chemistry news on Phys.org
We have a policy that we don't do your homework for you :) here's some hints:
Not too difficult, first look up or calculate the molecular weight of Li3N (mw), then compute the number of moles Li3N that you have, you get three times the number of moles LiOH out of the reaction, convert back to grams. mw is in grams/mole, so if you know the number of grams, you divide by mw to get the number of moles (and vice versa).
First determine how H2O2 reacts with water, and do the same as above.
Same thinking here, keep track of the reaction ratios (2 C6H6 produce 12 CO2), at STP a mole of any ideal gas occupies 22.4 liters.
nickel(II) nitrate reacts with sodium hydroxide according to the following equation: Ni(NO"3")"2" + 2NaOh --> Ni(OH)"2" + 2NaNO"3" [/B]
Again, same thing.
If your chemistry textbook is any good at all, there should be stoichiometry problems similar to the ones you are working.
H2O2 yields H2O + O2 and you'll have to balance the equation first.
Here's a little trick for conversions:
GMD = grams to moles, divide
MGM = moles to grams, multiply
LMD = liters to moles, divide (22.4L)
MLM = moles to liters, multiply (22.4L)
Very good tip:
I always have the following picture in my mind:
Code:
          * mw              * 6.022 x 10^23
grams     <--       moles      -->         molecules
                      |* 22.4L (at STP)
                      V
                    liters
It is all very simple, just remember that picture and the fact that you ALWAYS have to multiply when you go from the mole to any of the other measurements. And when you want to convert something into a mole, you ALWAYS divide.
Hope that makes things clearer
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
