How to find distance between 2 charges, with no force given?
  • Thread starter Thread starter Blooper
    Charges Force
To find the position of charge q3 so that the net force on it is zero, one must apply Coulomb's Law, which states that the force between two charges is proportional to the product of their magnitudes and inversely proportional to the square of the distance between them. Given charges q1 at the origin and q2 at 11.3 miles, the forces acting on q3 must be balanced. The actual force values are not needed; instead, the focus should be on setting the sum of the forces equal to zero. By expressing the forces in terms of the unknown distance r, one can solve for the position of q3. This approach allows for determining the required distance without needing specific force values.
Blooper
Three charges q1 q2 and q3 are set along the x-axis. q1 is at the origin and q2 is at r = 11.3mi
If q1 = +2.0C, q2 = +1.5C, and q3 = -2.3C, where must q3 be placed so that the net force on it is zero? In other words, the position of q3 is r3 = di, and you must find d. Answer in meters.
F = k(q1*q2)/r^2
I believe if I was given the force between the two, this question would be easy, but since no force is given, I'm not sure how to rearrange Coulomb's Law to isolate r (distance).
The actual values of the forces are irrelevant. All that matters is that they balance.
However, you do have enough information to find the forces in terms of the unknown coordinate.
Write out the expressions for the two forces.
F = k(q1*q2)/r^2
Start by writing ΣF = 0 for the system, from there, solve for the uknown r
