How to Find the Maximum Area of a Rectangle on a Parabola
  • Thread starter Thread starter Jude075
    Area Maximum
The problem involves finding the maximum area of a rectangle that has its base on the x-axis and vertices on the positive portion of the parabola defined by the equation \( y=2-3x^2 \). The original poster presents multiple choice answers for the maximum area.
  • Participants discuss the area of the rectangle in terms of its dimensions and the parabola's equation. There are attempts to derive the area function and questions about the correct intercepts of the parabola. Some participants express uncertainty about the methods to maximize the area, debating whether to derive or integrate the area function.
The discussion is ongoing, with participants exploring different interpretations of the problem and the area function. Some guidance has been offered regarding the formulation of the area, but there is no explicit consensus on the method to find the maximum area.
There are noted discrepancies regarding the intercepts of the parabola, which may affect the setup of the problem. Participants are also considering the implications of the rectangle's dimensions and the area function derived from the parabola.
Jude075
A rectangle has its base on the x-axis and its vertices on the positive portion of the parabola
$$ y=2-3x^2 $$
What is the maximum possible area of this rectangle?
A. (8/27)*181/2 B.(2/9)*181/2 C. (4/15)*301/2 D.(2/15)*301/2 E.(1/3)*121/2
The definite integral (or the area underneath the curve) from 2/3 to-2/3, which are the x-intercepts, is 56/27 .Since the rectangle is inside the parabola, I just need to find the number that is the closest. It is choice C, but the answer turns out to be A.
The intercepts of y = 2 - 3x^2 are NOT 2/3 and -2/3. Maybe this is your problem?
If you draw a rectangle with base length 2x with the conditions you gave, the area of the rectangle is [itex]4x - 6x^3[/itex]. This function has derivative [itex]4 - 18x^2[/itex], which becomes zero at...
Can you continue the solution?
If the upper corners of the rectangle are at (x, y) and (-x, y) then the area of the rectangle is 2xy.
Since [itex]y= 2- 3x^2[/itex], that area is [tex]2x(2- 3x^2)= 4x- 6x^3[/tex].
So how do you guys use that expression to find its area? Do I derive it or integrate it?
You now have a function
[tex]A=4x-6x^3[/tex]
Where A stands for area. For different values of x, you'll get a different value of A, correct? You want to find the maximum area the rectangle can be, hence, you want to find the maximum of A, so how do you do that?
  • · Replies 30 ·
