D H said:
What you did was to miss the possibility that x can be negative by saying γ=x/|d-x|. A negative value for x doesn't make a lick of sense; it would obviously violate the concept of "betweenness". What you could have said is that γ=|x|/|d-x| and then rejected negative values of x and negative values of d-x, leaving γ=x/(d-x) as the only viable solution.
That some adroit manipulation automagically removes non-solutions happens surprisingly often. Teaching how to recognize where these manipulations are applicable - that's tough. I just went with the flow and worked with the students who saw this as a quadratic problem.
Students also have to be taught to read the problem text carefully and understand it. They should be encouraged to draw a figure. I recognized here in PF, and I was very much surprised, that the students do not read, do not draw and do not understand. Lot of students see only equations and manipulate them mechanically without thinking.
The question was, where to put an object
between Mercury and Sun so the net force of gravity is zero.
'Between' means a position along the straight line connected Mercury and Sun. Let they be d distance apart, and choose a point between them at distance x from the Mercury. 'Distance' is positive by definition. The point is at distance d-x from the Sun, and it is also positive, because the point is
in between, x<d. So it is safe to take the square root of the equation M
m/x
2=Ms/(d-x)
2.
To teach elementary geometric concepts and logic has to be prior to teaching quadratic equations. And to tell the truth, I did not address my previous post to the OP. I addressed all of you discussing the solution of a quadratic equation instead of applying simple logic. By the way, the method of taking the square root of the equation a/x
2=b/(d-x)
is useful even in cases when x and/or d-x can be negative. You need only apply the absolute value: √ (a/b)=|x/(d-x)| and inspect the possibilities. I teach my pupils that method to spare extra work and prevent them introducing extra rounding errors.
ehild
