How to find the surface area of a spherical triangle?
prinsinn
Hello
I have a spherical triangle with the radius 1, and I have tried so hard to find the surface area. I know that A=120°, b=90° and c=60°.
I could calculate that B=73.89° and C=56.31° and a=115.66°.
I think I should use the formula
(ABC) = (A + B + C - pi) r2
I always get the wrong answer but the correct one is 1.2254.
Can someone please tell me what to do, thanks.
Go on Wikipedia and Look up some of Gausses work on Spherical Trig, it should have an analogous result to Euclidean Planes area of a triangle (half a b sine c).
Girard's Theorem states that the sum of the angles of a triangle drawn on a sphere is not 180 degrees but the sum differs from 180 degrees by the area of the triangle divided by the radius squared.
hello prinsinn! :smile:
(have a pi: π :wink:)
well, your formula is correct, and using your A B and C i do get 1.2254 :confused:
Did you remember to convert the angles to radians?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
