How to predict how far a spinning ball will bounce?
To predict how far a spinning ball will bounce, one must consider the effects of angular velocity and surface roughness. The rougher the surface, the greater the potential horizontal distance due to increased friction. However, the relationship between angular velocity and friction coefficients is complex and not directly correlated. A clear understanding of relevant equations and an attempt to solve the problem are necessary for a comprehensive analysis. Overall, quantifying the bounce distance requires a detailed examination of both spin dynamics and surface interactions.
mousemat
If I were to drop a spinning ball vertically, the spin would cause the ball to bounce a certain horizontal difference. Intuitively, the rougher the surface it bounces against, the further the ball should bounce. How would you quantify this relationship?
I honestly have no idea where to start, which is why I'm posting here xD
Thanks!
Welcome to PF!
Your question has not much sense. Write the whole text of the problem.
And fill in the template. What are the relevant equations? What is angular velocity? How friction can influence it? You also need to show some attempt to solve the problem.
In general angular velocity of a rotating body is not related to some coefficient of friction. What is the relationship between the angular velocity of the rotating Earth to the coefficient of friction between rubber and asphalt, for example?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
