How to simplify 1/(cos^4x+sin^4x)
  • Thread starter Thread starter color_me
    Simplify
To simplify 1/(cos^4x + sin^4x), start by using the fundamental identity sin^2x + cos^2x = 1 and square both sides. This leads to a more manageable expression involving sin^4x and cos^4x. Isolate these terms and apply various trigonometric identities to simplify further. Ultimately, substituting the simplified expression back into the original equation will yield the desired result. The process may involve some complexity, but systematic manipulation of identities can lead to a solution.
color_me
Simplify 1/(cos^4x+sin^4x)
One can't apply cosine of a difference when the cosine is raised to a power, right?
I tried using several trig identities, but it doesn't get any simpler.
Thank you for any help in advance!
try replacing sin2x with 1-cos2x or the other way around.
Try starting with the fundamental identity sin^{2}x + cos^{2}x=1. Square both sides and foil. This might get messy, but if you keep all your terms in order you will be in good shape. Next, look for your sin^{4}x and cos^{4}x values. You want to isolate them on one side and have the other terms on the other side. Now, you have to go to work with the other trig identities on the rest of the terms. I was able to do it product identities. In the end, you should have sin^{4}x+cos^{4}x=something. The last step is to plug this into your original equation 1/sin^{4}x+cos^{4}x.
Thanks for the help! I figured it out.
