I How to solve this system of equations of trig functions
ual8658
I've written it out and it seems impossible. I get -50(sin^2(alpha)) = 86.63 cos(alpha) sin(alpha) - 6.54. Where would I go from there?
Mathematics news on Phys.org
Assuming the first term is ## (75 cos(\alpha))t ## and not ## 75 cos(\alpha t) ##, the equation is a quadratic in t, and has a completely separate solution from ## t=1.155/( sin(\alpha)) ##. If the second case is indeed what is asked for, the solution is non-trivial, and a numeric solution, e.g. by graphing a couple of the terms and finding where they intersect, would be in order.
Likes Logical Dog
There is an analytic solution. Based on your current progress: Replace the cosine using the sine, then simplify. You'll get a quadratic equation to solve (with a small trick involved).
Likes Logical Dog and Charles Link
Well, you can rewrite it as:
86.63 cos(\alpha) sin(\alpha) = 6.54 - 50(sin^2(\alpha))
You can rewrite cos(\alpha) = \sqrt{1-sin^2(\alpha)} to get an equation only involving sin(\alpha). Alternatively, you could use the double-angle formulas:
sin(2 \alpha) = 2 sin(\alpha) cos(\alpha)
cos(2 \alpha) = 1 - 2 sin^2(\alpha)
Likes Charles Link
My mistake, I overlooked the solution that @mfb is referring to. It's essentially two equations and two unknowns.
Likes ual8658
This is going way over my head. Could you elaborate?
I tried using the double angle formula with sin(2 alpha) but I'm still stuck after that.
When you substitute with ## cos(\alpha)=\sqrt{1-sin^2(\alpha)} ## , you then square both sides of the equation and get a quadratic equation in ## u=sin^2(\alpha) ##. (It is actually 4th power in ## sin(\alpha) ## , but there is no ## sin^3(\alpha) ## term and no ## sin(\alpha) ## term=it is quadratic in ## sin^2(\alpha) ##.
Thank you! I got it now.
Likes Charles Link
