Hydraulic Damping Information Needed
The discussion centers on the search for practical resources on hydraulic damping in suspension systems, specifically for improving the damping circuit of a Rockshox Boxxer fork. The original poster, a mechanical engineering student at Aston University, expresses frustration over the lack of relevant texts in their library. They note that while there is ample information on suspension geometries for cars, resources on oil bath damping are scarce. Other participants question the library's offerings and suggest that the poster may not be searching in the right sections. The conversation highlights a need for more accessible information on hydraulic damping for mountain bike suspension tuning.
shalmaneser
1st of all - Hi everyone, this looks like a great resource, hopefully i'll be a frequent visitor!
Anyway, the reason for this post is to findout if anyone knows of any texts concerning the more practical (design) side of hydraulic damping used in suspension systems.
Im at uni in England at the moment doind Mechanical engineering, but i don't seem to be able to find any books on the subject in our library. Maybe I am not looking hard enough.
The reason i am looking for this information is purely interest - i ride mountainbikes in my spare time, and i was looking for a way to improve the damping circuit on my suspension fork, a 'Rockshox Boxxer' fork if anyone is interested.
I know it can be done, as there are several suspension tuning companies in England that cater specifically for mountainbikers (www.tftuned.com, for example) i was just wondering where the information that they obviously use comes from.
I would like to improve the consistancy of the damping, as well as making the damping smoother.
Any help or advice would be very much appreciated!
Adam.
Boxxers, they're coil spring with oil damping right?
What uni are you at? I find it hard to believe that your library doesn't have the necessary books, ours is rammed with this kind of thing.
yeah, that's the one.
i must admit i was suprised at the lack of information, but I am not sure how specialist the subject is. there is a lot of information about suspension geometries as regards cars (anti squat and roll centres etc etc) but nothing at all about oil bath damping :cry: . Most of it is about damping pistons, which isn't really all that useful. I could be looking in the wrong bit of the library, I am not too sure...
Im at Aston Uni in Birmingham, by the way.
Still, any help much appreciated.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
