Hyperbolic path in Minkowski space
7 replies · 3K views
luitzen
The path described by a constantly accelerating particle is given by:
[itex]x=c\sqrt{c^2/a'^2+t^2}[/itex]
where a prime denotes an observer traveling with the particle and a letter without a prime a resting observer.
If we leave the [itex]c^2/a'^2[/itex] out it reduces to x=ct, which makes sense. The distance traveled by a photon is simply it's speed times the travel time. If we think of a constantly accelerating particle, a particle which would first need to accelerate to a speed c (or at least close to it), we would expect that it would travel a shorter distance in the same amount of time, since it would first need to accelerate and hence travel at a smaller average speed. However, when you look at the equation above, you can see the travel time gets a little bonus, [itex]c^2/a'^2[/itex]:
[itex]x=c\left[t+f\left(c^2/a'^2\right)\right][/itex]
According to the equation, the slower one accelerates, the larger distance one will be able to travel. To me that does not make any sense at all, so I wondered whether I made any mistakes and decided to verify the answer on the internet. However, without blinking an eye, every single source I find online gives me the same answer.
So where do I go wrong in all this?
Sources:
http://en.wikipedia.org/wiki/Hyperbolic_motion_(relativity )
http://www.physik.uni-leipzig.de/~schiller/ed10/Uniform relativistic acceleration.pdf
[itex]x\left(t=0\right)=c^2/a'[/itex]
So I should define a new axis x'' then?
[itex]x''=x-c^2/a'=c\sqrt{c^2/a'^2+t^2}-c^2/a'=c\left(\sqrt{c^2/a'^2+t^2}-c/a'\right)[/itex]
If a' goes to infinity:
[itex]x''=ct[/itex]
If a' goes to zero:
[itex]x''=c\left(\sqrt{c^2/a'^2}-c/a'\right)=0[/itex]
Let's say a'=0.5c/yr, t=5 yr:
[itex]x''=c\left(\sqrt{4+25}-2\right)=2.39ly[/itex]
t=infinity:
[itex]x''=c\left(\sqrt{c^2/a'^2+t^2}-c/a'\right)=c\left(\sqrt{t^2}-c/a'\right)=c\left(t-c/a'\right)=ct[/itex]
This makes all sense to me. Thank you.
This source http://math.ucr.edu/home/baez/physics/Relativity/SR/rocket.html gives the distance traveled as:
[tex]d =\frac{c^2}{a}\left(\sqrt{1+\left(\frac{at}{c}\right)^2}-1\right)[/tex]
d in this case increases with increasing proper acceleration a.
For your example in your second post, when a=0.5c/yr, t=5 yr, d=3.385 lyr.
It's the same, but I made a calculation error. I did [itex]\sqrt{25+4}-3[/itex] instead of [itex]\sqrt{25+4}-2[/itex]
I prefer my version though, since it's in the form of c times a time.
In my formula it's also much more obvious that d increases with increasing a'.
Here is how to get from the equation given in the Baez link I posted, to the equations in your links.
Starting with:
which can be rewritten as:
[tex]d =\sqrt{\frac{c^4}{a^2}+c^2t^2}-\frac{c^2}{a}[/tex]
where d=0 when time t=0.
In the Rindler coordinate system (X,T), the distance from the origin is c^2/a at time T=0 and the proper acceleration (α) of a given particle is proportional to c^2/X also at T=0. This means that the above equation can be written in terms of X as:
[tex]X = d+\frac{c^2}{\alpha} = \sqrt{\frac{c^4}{\alpha^2}+c^2T^2}[/tex]
which is essentially your equation at the start of this thread. Note that α is constrained to be the value of c^2/X at time T=0.
P.S. I see I missed your post while posting this and that you had already figured this out. I was thrown by the fact you got a different result but that was just a numerical error.
If we rearrange that equation in terms of the co-ordinate time we get this:
[tex]t =\sqrt{\left(\frac{2d}{a}\right)+\left(\frac{d}{c}\right)^2}[/tex]
...so the co-ordinate time can be thought of as having two time components - the Newtonian time to travel a displacement d at a constant acceleration a, and the light travel time. I'm not sure if that makes sense, but that's how it looks to me from the equations.
