What Does (I) Stand for After a Chemical Compound?
  • Thread starter Thread starter chuckset
    Chemical
The notation "(I)" after a chemical compound like H2SO4 is actually a typographical error; it should be "(l)", which signifies that the substance is in a pure liquid state. The standard notations for states of matter in chemistry are (g) for gas, (l) for liquid, (s) for solid, and (aq) for aqueous solutions. Additionally, "(I)" can refer to the oxidation state in compounds like Copper(I) Iodide, indicating the charge of the copper atom.
chuckset
I was wondering what (I) means when it is written after a chemical compound, for example, H2SO4 (I). Thanks!
Chemistry news on Phys.org
It's not an I, it's an L, and indicates that the Hydrogen Sulfate is in a pure liquid state.
It couldn't be an I, as the four states are (g), (l), (s), and (aq).
Now, there is a case where (I) is used in a compound, such as Copper(I) Iodide, and that indicates the charge of the copper atom.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
