I can't seem to follow the manipulation of the equation
  • Thread starter Thread starter Kasper Larssen
    Manipulation
Kasper Larssen
Member warned that the homework template must be used
Hello!
In the picture below, i can't seem to understand how they get from the first line, to the second line.
Fal3T
(https://imgur.com/a/Fal3T)
When i write it up as dr/dT on the leftside, and separate the r's and the T's, i get dr/((1/2)*r-(1/16)*r^5)=dT which is not the same as in the picture.
Where do i go wrong?
How is it not the same thing? It is exactly the same thing just factorising out ##r/2## from the denominator.
Kasper Larssen said:
Hello!
Fal3T
You forgot Algebra 101: just multiply your numerator and denominator by 2.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
