I do not understand this problem with friction,
  • Thread starter Thread starter nfg5
    Friction
The problem involves two masses, m1 and m2, connected by a string over a frictionless pulley, with m1 subjected to a force at an angle. The coefficient of kinetic friction between m1 and the surface is 0.213, which affects the net force acting on m1. To find the upward acceleration of m2, one must first calculate the effective force on m1 considering the angle of the applied force and the frictional force opposing its motion. The acceleration of m1 can then be determined using Newton's second law, ensuring both masses share the same acceleration due to their connection. Understanding the components of the applied force and the impact of friction is crucial for solving the problem.
nfg5
Mass m1=27.1 kg is on a horizontal surface, connected to mass m2= 7.10 kg by a light string which is hanging. The pulley has negligible mass and no friction. A force of 232.9 N acts on m1 at an angle of 31.7 degrees.
The coefficient of kinetic friction between m1 and the surface is 0.213. Determine the upward acceleration of m2.
What part of the problem is giving you trouble?
I no both with have the same acceleration but how do I find the acceleration of the m1 if it's being pulled at an angle?
