I don't know where went wrong help needed
  • Thread starter Thread starter lmlgrey
The problem involves calculating the speed of a charged pellet accelerating between two parallel conducting plates with a potential difference of 4.50E+3 V. The initial calculation of work done on the charge was correct, resulting in 3.4875*10^-3 J. However, the error arose from using the mass in grams instead of kilograms, which is necessary for consistency with SI units. After converting the mass to kilograms, the correct speed can be recalculated. Proper unit conversion is essential for accurate results in physics problems.
lmlgrey
1. Two parallel conducting plates that are in deep space are brought to a potential difference of 4.50E+3 V, and a small pellet of mass 5.70 mg carrying a charge of 7.75*10^-7C accelerates from rest from the positive plate. With what speed will it reach the other plate?
It seemed pretty obvious for me that by multiplying the potential difference and the charge on the pellet, the work done on the charge will be calculated. This work is equivalent to the kinetic energy of the pellet,
So change in U = 4.5*10^3 V * 7.75*10^-7 C = 3.4875*10^-3 J
and change in U = Kinetic energy = 0.5*(0.0057g)*v^2
solving for V I got v= 1.106 m/s
but the answer is wrong... can someone give me a hint?
Kilogram is the SI standard mass unit to use with Joules. Convert the mass accordingly.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
