I give up Basketball Projectile problem.
The problem involves a basketball projectile motion scenario where a player shoots from a height of 2.20 meters towards a basket at 2.90 meters, at a 40.0-degree angle, from a horizontal distance of 6.00 meters. The task is to determine the range of initial speeds required for the shot to be successful within a specified horizontal accuracy.
  • Mixed
  • Participants discuss the validity of a derived range formula and its applicability given the differing initial and final heights. There are attempts to apply kinematic equations and projectile motion principles, with some participants expressing frustration over previous methods that did not yield correct results.
Some participants have provided insights into the conditions under which certain formulas are valid, while others have shared their attempts and challenges in applying these equations. There is a recognition of the need to derive the correct equations of motion for both horizontal and vertical components, and some guidance has been offered regarding the approach to solving for initial velocity.
Participants note the constraints of the problem, including the requirement for accuracy in the horizontal distance and the impending deadline for homework submission. There is also mention of the emotional impact of the problem on the original poster, who expresses a desire for assistance before seeking help at their college.
kieth89
A basketball leaves a player's hands at a height of 2.20 above the floor. The basket is 2.90 above the floor. The player likes to shoot the ball at a 40.0 degree angle.
If the shot is made from a horizontal distance of 6.00 and must be accurate to plus or minus .22 m(horizontally), what is the range of initial speeds allowed to make the basket?
Express your answer using two significant figures.
2d kinematic equations and projectile equations.
I'm really tired and sick of this problem, and only have one more try I can use in the homework problem. So far I've tried:
following the basic method used here: http://answers.yahoo.com/question/index?qid=20070930112245AAlbiKZ , but it didn't work.. So then I tried here: http://answers.yahoo.com/question/index?qid=20091012202754AAuIjr2 , but it didn't work either. So then I used my own derived formula for range :
[itex]R = \frac{2v_{0}^{2}sin \Theta cos \Theta}{g}[/itex]...and using this didn't work either. And now I only have one more try before I'm done with the problem. So I need to get it right. Honestly, I thought my Physics class would be kind of fun and interesting, but right now I absolutely hate it and have no idea how to solve these problems. I'm going to get help at my college Monday, but this homework is due tomorrow, so I need to figure this problem out.
Thanks for any help,
Josh
Josh
What are the conditions for which this range formula is valid?
[itex]\displaystyle <br /> R = \frac{2v_{0}^{2}\sin \theta \cos \theta}{g}\ ?[/itex]​
It's valid for the case in which the final vertical position is the same as the initial vertical position. That's not the case here.
What is the horizontal equation of motion appropriate for this problem ?
What is the verticalal equation of motion appropriate for this problem ?
Added in Edit:
The first link you gave gives the solution to essentially the same problem, with a couple of the numbers changed. What was you problem with working with that method? It was done correctly.
Added in Edit:
Plugging the numbers into that formula results in taking the square root of a negative..and there should be no i in this Physics problem. With my values plugged in the equation looks like this (for the high end):
[itex]v_{0} = \sqrt{6.22 tan(40°) - 9.8 x^{2} (\frac{1 + tan(40°)^{2}}{2*0.7}}[/itex]
Which ends up imaginary...
Well, you're right! That final result is wrong (in the link). Their initial equations for x & y look good.
[itex]\displaystyle \Delta x=v_0\cos(\theta)t[/itex]
[itex]\displaystyle \Delta y=v_0\sin(\theta)t-\frac{1}{2}gt^2[/itex]
Solve the first equation for t. Plug that result into the second equation, then solve for v0.
Thanks for the help..I figured it out, but the program didn't like how I formatted my answer (gave it the range instead of the difference between the two extremes) so I still got it wrong :(...At least I know how to do it for the test now though.
11K
10K
  • · Replies 17 ·
