Calculating Force and Power in Elevator Systems- Step by Step Guide
  • Thread starter Thread starter KraYzie
The discussion focuses on calculating force and power in elevator systems, specifically through two problems involving an electron's acceleration and an elevator's motor power requirements. For the first problem, participants are encouraged to show their work and apply the correct equations, such as W = Fd, to find the force needed to accelerate an electron. The second problem involves determining the power required for an elevator motor to lift a fully loaded car, factoring in frictional forces and the impact of a counterweight. Participants express confusion over the calculations and seek assistance in understanding the underlying principles. Overall, the thread emphasizes the importance of demonstrating work in problem-solving for clarity and accuracy.
KraYzie
How do you do these problems:
1) What is the magnitude of the force required to accelerate an electron of mass 9.1x10^-31 kg from rest to a speed of 2.0x10^7 m/s for a distance of 0.5 cm
(a) 1.8 x 10^-21 N
(b) 9.0 x 10^-19 N
(c) 1.8 x 10^-16 N
(d) 3.6 x 10^-14 N
2) In an elevator system, a motor rotates a shaft wrapping or unwrapping a chain that raises or lowers the elevator car. The car's mass is 1.20x10^3 kg and is designed to carry a maximum load of 9.5x10^2 kg. While in motion, a constant frictional force of 3.5x10^4 N acts on the car.
(a) What power must the motor deliver to raise the fully loaded car at a speed of 2.5 m/s?
(b) The elevator system is modified by connecting a free-hanging 5.0x10^2 kg counterweight to the chain that passes over the shaft of the motor, as shown below. What power must the motor now deliver to raise the fully loaded car at a speed of 2.5 m/s?
Thank you very much
Welcome to PF, KraYzie. Please note that for homework problems, we ask you to show your work before we can help you.
Do you have any thoughts on the questions?
for #1 I used W = Fd. I changed the .5cm to .005m but i quite cannot get the answer.
I have no clue about #3 :(
This isn't showing your working; it is a stating one brief point. How do you intend to use work to solve this problem?
Well, to start with, do you know any equations relating power and force?
yeah I know P = W/T
for #2, I have this answer written down which is C but I don't know how I got it because I just punched numbers into the calculator omg I'm so screwed
can somebody really help me? I have been trying since yesterday. Please
