Converting 8.2 x 10^19 pm to miles | Practice with Conversions Homework
  • Thread starter Thread starter cwalker8184
The discussion focuses on converting 8.2 x 10^19 picometers (pm) to miles. Participants clarify that "pm" likely refers to picometers, a unit of distance. One user attempted the conversion by multiplying by 10^-12 and dividing by 1609, resulting in 5.4 x 10^9. There is confusion regarding the clarity of the original question and the conversion process. Overall, the thread highlights the need for clear definitions and proper unit conversions in mathematical problems.
cwalker8184
Convert 8.2 x 10 to the 19 power pm to miles
Convert 1.5 ft to inches
I multiplied 8.2 x 10 to the 19 power times 10 to the negative 12 power and then divided it by 1609 and got 5.4 x 10 to the ninth power
Your question isn't very clear to me
Not clear to me either. What's a "pm"? Some distance measurement?
Also, if you click the Sigma symbol in the Advanced Reply menu, you can put your equations into LaTeX to make them clearer. Like:
D = 8.2 * 10^{19}
I believe that "pm" would stand for "picometers". The op can correct me if I am wrong.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
