What is the current flowing through the aluminum rod on tilted conducting rails?
  • Thread starter Thread starter MrDMD83
    Point
The discussion centers on calculating the current flowing through an aluminum rod sliding down tilted conducting rails in a vertical magnetic field. The rails are inclined at 30.0° and the magnetic field strength is 0.053 T. The rod, weighing 0.20 kg and measuring 1.6 m in length, moves at a constant velocity, indicating that the forces acting on it are balanced. The conversation highlights that the original poster has not demonstrated any prior work or understanding of the physics involved. The thread is ultimately redirected to a physics homework category for further assistance.
MrDMD83
partscoretotalsubmissions1014/50The two conducting rails in the drawing are tilted upwards so they make an angle of 30.0° with respect to the ground. The vertical magnetic field has a magnitude of 0.053 T. The 0.20 kg aluminum rod (length = 1.6 m) slides without friction down the rails at a constant velocity. How much current flows through the bar?
?? If there are "points" involve then this is either homework or a test. Also it is clearly physics, not mathematics. And you have not shown that you have done anything yourself. You did just about everything wrong!
I'm moving this to physics homework.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
