Calculating Time and Forces with Frictionless Surfaces
  • Thread starter Thread starter zell_D
    Final
A woman weighing 730N on a frictionless pond throws a 1.2kg backpack to propel herself, taking approximately 62.07 seconds to reach the shore. For the second problem involving two blocks on a frictionless surface, the forces between the blocks are determined by their masses and the applied force, with both blocks accelerating together. The third problem focuses on calculating the thickness of a bubble's skin using the volume of the bubble and the density of bubble gum, leading to confusion about whether to consider the outer or inner layer of the bubble. Clarifications on the normal forces and action-reaction pairs are provided, emphasizing the need to balance forces and account for the bubble's surface area in calculations. Overall, the discussion highlights the application of fundamental physics concepts to solve problems involving motion and forces.
zell_D
1. A woman weighing 730N stands in the middle of a frozen pond of radius 5m. She is unable
to get to the other side because of a lack of friction between her shoes and the ice. To propel
herself, she throws a 1.2kg backpack horizontally towards the south shore at a speed of 5m/s.
How long does it take her to reach the north shore?
2. Two blocks are in contact on a frictionless surface., sitting horizontally next to each other. You apply a force of 3.2N to block 1 such that it pushes against block two. Mass of block 1 = 3.2kg. Mass of block 2 = 1.2 kg. What is the magnitude of the force between the two blocks?
3.The density of bubble gum is about 1g per cubic cm. You blow an 8g wad of gum into a
bubble with a 10cm diameter. What is the thickness of the bubble's skin?
1. conservation of momentum (explosion?) (Mass A + Mass B)V initial = Mass A*V A + Mass B * V B?
2. F=ma F=0
3. no idea? 4/3pi r^3?
I did number 1, my answer came out to be something like 62.07 seconds but i am not sure if its right. Need someone to check for me. (I set the initial velocity to zero since the backpack on the woman AND the woman were in the middle of the pond not moving right?)
number 2 and 3 i have no idea, i drew the diagrams out but does the box being pushed on have a normal force pushing back or no?
number 3 i just have absolutely NO idea lol
Problem 1 is correct.
For problem 2, draw the free body diagram. Normal forces on the blocks are balanced by the weights of the blocks.
Consider action and reaction forces acting on block 2 and block one.
Both the blocks must move with the same acceleration.
In problem 3, Surface area of the sphere is given by A = 4*pi*r^2. If t is the thickness of the skin, find the volume. Volume X density = mass of the bubble gum.
Likes nads_1019
I got everything now cept for number 3. Ok so i find the surface area and i have the volume, so we find the thickness of what? the bubble or the bubble gum? >.<
Mass of the bubble gum = Area of the bubble*thickness of the bubble*density of the bubble gum
Likes nads_1019
i did that but the answer came out to be .025 CM but the answer is .02 mm on the practice so i am confused
I think the teacher said something about subtracting the outer layer with inner layer or something like that
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
