I want to know about electricity.i am facing a huge difficulty in it.
  • Thread starter Thread starter Shashank tekri
    Difficulty
The discussion revolves around understanding the role of resistors in electrical circuits, specifically how they affect the current flowing through them. The subject area is electricity, focusing on concepts of resistance, current, and voltage relationships.
  • Participants explore whether resistors affect current, with some suggesting that resistance alters electron movement. Analogies involving rolling balls and water flow are used to illustrate the concept of resistance impeding current.
The discussion is active, with participants providing analogies and explanations to clarify the relationship between resistance and current. There is a mix of interpretations and attempts to conceptualize the effects of resistors, but no consensus has been reached on a definitive explanation.
Some participants express difficulty in understanding the fundamental concepts, indicating a need for clearer explanations or additional examples. The use of analogies suggests an exploration of different ways to grasp the material.
Shashank tekri
helo i am facing difficulty in understanding a question, help is required.
does the resistor affect the current flowing in a circuit if yes why and if no why.
I think it affects the current flowing through it as the resistor affects voltage. please help
Look at it this way:
A resistor acts to alter the movement of electrons through the material.
The movement of electrons is the current.
So the resistance affects the current.
In mathematical terms the resistance is the voltage divided by the current - a three way relationship so varying one value will mean one or both of the other terms must also change.
A useful analogy for understanding why a resistor impedes current is the following:
Imagine you have balls rolling down a smooth hill (potential difference), and they will roll down this hill as quick as possible if there is nothing in the way. However, imagine now that the hill is covered in thick grass (resistor), and now their motion is slowed down by the obstacle in their way. So, a resistor can be thought of as an obstacle for that the electrons have to overcome, and thus cause their motion to slow down. Hope that helps; it's always useful to find analogies when learning new material.
The water analogy isn't perfect but... Think of a resistor as a restriction in a water pipe. The smaller the hole in the restriction the greater the resistance to water flow.
If the pipe with restriction is connected to a water source, one that provides constant water pressure (=voltage), then the greater the resistance..
1) the less water flows through it.
2) the greater the pressure (voltage) drop across the restriction.
  • · Replies 16 ·
