Ideal coil size for a low wind turbine.
The discussion focuses on designing a low wind speed wind turbine, specifically addressing the ideal coil size and wire gauge for maximizing power output from coils paired with N52 magnets. Participants explore various configurations, specifications, and theoretical calculations related to coil design and expected electrical output.
  • One participant seeks guidance on coil specifications, including diameter, wire gauge, number of turns, and layers, for a wind turbine using a specific magnet size and type.
  • Another participant shares their experience with a similar setup, suggesting a maximum output of about 12 volts and 1 amp at low RPMs, using 400 turns of 30 gauge wire across 9 coils.
  • Concerns are raised about wire gauge limitations, with one participant noting that 30 AWG wire may not handle more than 0.86 amps without risk of burning out.
  • There is mention of using magnetic levitation to optimize the turbine's position relative to the coils, with adjustments made for weight to achieve the desired levitation level.
  • A participant expresses curiosity about inverters capable of handling high AC voltage outputs from wind turbines, indicating a lack of available resources for such equipment.
  • Discussion includes references to Faraday's law and the need for clarification on symbols and formulas related to calculating electrical output from the turbine.
  • Another participant suggests that flat coils may provide better gauge penetration and that more windings and higher RPMs could yield higher voltage outputs.
Participants express a range of views on the expected performance and design of the wind turbine, with no consensus on the ideal specifications or outcomes. Some share personal experiences while others question the feasibility of achieving higher outputs.
Participants reference various assumptions about wind conditions, magnet specifications, and wire capabilities, which may affect the overall design and expected performance of the wind turbine. There are unresolved mathematical steps and definitions related to the calculations discussed.
Individuals interested in DIY wind turbine design, electrical engineering, and renewable energy applications may find this discussion relevant.
robin9000
I can't find anything I can make heads or tails out of so if you guys can help I thank you.
I would like to design a wind turbine and be able to get as much power as I can out of each of it's coils. If I start with a magnet that is 1.1811" in Diameter and it is .125" thick with a grade of N52 and I only allow for a air space of .0625" between the magnets and coils what would be the ideal coil size / wire gauge to use and so forth.
I can't find the exact specs for that particular magnet but from looking at another very similar one the spc's for the magnet would be approximately as follows;
N52
Br: >=14,800 Gauss
Bhmax: 52MGOe
Surface Field: 918 Gauss
Given I make the inside of the coil the diameter 1.1811", (the diameter of the magnet) what
are the other specs I should use to make the coils if I want it to generate power at a low wind speed. I'm thinking it would not be able to go much faster then 300rpm. (my best guess)
So in other words how many loops across should I go with the coil and how many layers of coils should I go and with what gauge of wire.
Also given 300rpm how many volts / amps / watts would the finished coil put out.
Thanks and sorry if I'm missing something here, I'm no physics expert by any means.
It all depends on what you want to do. I've built one a couple of years ago using the same pretty much the same size and type magnets and I suggest to try a search on building wind turbines. Don't expect to get more than about 12 volts and 1 amp out of it if your using it for battery charging at that low a rpm speed.
I used 400 turns of 30 gage magnet wire for the coils. 9 coils with 12 magnets per outside rotor.
You can see it here: http://www.packratworkshop.com/wind4.htm
I was driving mine with a 3' Savonious type rotor maxing out about 450 rpm on a good windy day. I'm in Wilmington NC and we don't get a lot of wind here along the coast except for morning and evening breezes on and off the ocean.
This would be a good place to start for more information: http://www.scoraigwind.com/index.htm
That guy probably knows more about that type of wind turbine alternator than just about anyone you might run across.
My fault I should have shown how I was planing on laying out the coils. As you can now see
in the picture I attached the coils are represented as those circles below. I have the turbine
lifted away from the coils so you can see them but when done the turbine will float just above
the coils using a magnetic levitation in the middle and I will use a shaft to stabilize the whole thing.
I'll use weight to adjust to get the exact levitation level correct so the turbine with the magnets floats just above the coils of wire. Oh and by the way according to the wire guide 1AMP on 30AWG
wire would break the code / thus burn your wire. That very thin wire is only rated for .86 AMPS.
Hope this makes sense.
Your setting up a standard design for a typical turbine.
Yes, I know that wire I used was small and what it is rated for. It was the only way I could to get the coils flat enough for the thin magnets to have any worthwhile affect. I wasn't suggesting you do the same.
I just told you how mine was setup, that's all. My turbine normally put out about 1/2 amp in operation. We don't get a lot of wind here, it's a class 1 area and I wasn't too worried about burning out the coils as this was nothing more than a demonstration setup to show a small wind turbine would work here even if not well.
Very curious to the one reply with the guy who made one with high volts, where on Earth did you
get a inverter that could take the high AC voltage and convert it to usable AC voltage for the grid? Been looking my self and can't find a inverter like that.
They are N52's so they should ideally give a lot of electric current for their size, this is what I I'm thinking. I realize Farady's law would help in making the calculations but I can't figure out what the symbols stand for.
for example what dose the triangle mean.? ∇
These symbols are part of my biggest problem.
I also am not sure how to use the formula to figure out the watts I would finally get per revolution.
If someone could give a demo example on how to use the formula that would really help.
N = -1 * (-V/change in (( tesla * area meters squared)/ seconds))
Turns= -1 (-V (( magnet strength * magnet size ) / magnet speed))
Flat coils work best as the gause penetration is better
More winding higher voltage
Faster RPM gives higher voltage
Thicker wires gives higher amperage
  • · Replies 28 ·
18K
  • · Replies 17 ·
  • · Replies 37 ·
