How Does Adiabatic Expansion Affect Ideal Gas Pressure?
In an adiabatic expansion of an ideal gas, the pressure decreases as the volume increases. The relationship between pressure and volume is expressed by the equation P1V1^gamma = P2V2^gamma. For a 50% increase in volume, V2 is 1.5 times V1, leading to a pressure reduction factor of approximately 2, calculated as P2 = P1/(3/2)^gamma. The setup of the calculation uses the ratio of pressures (P1/P2) equal to the ratio of volumes (V2/V1) raised to the power of gamma, which is a standard approach in thermodynamics to relate changes in state variables. Understanding this relationship clarifies why the pressure decreases as the gas expands adiabatically.
trah22
an ideal gas is allowed to expand adiabatically until its volume increases by 50%. By what factor is the pressured reduced?(gamma=5/3)
P1V1^gamma=P2V2^gamma
v2=v1+.5V1=3/2V1
(p1/P2)=(v2/v1)^gamma=(3/2v1/v1)^gamma=3/2^gamma
so P2=P1/(3/2)^gamma=0.51P1 sp P2=.5P1
so reduced by approximately factor of 2
This is actually the correct answer, but i don't understand the why the intial setup of the calculation, is P1/P2=(V2/V1)^gamma, the problem is looking for the reduction of the pressure, could someone explain why your suppose to set up calculation this way?
more specifically why do you put p1 over p2 (p1/p2) equal to v2 over v1 (v2/v1) in solving this problem?
?? It is just algebra:
P_1V_1^\gamma = K = P_2V_2^\gamma
\frac{P_1V_1^\gamma}{P_2} = V_2^\gamma
\frac{P_1}{P_2} = \frac{V_2^\gamma}{V_1^\gamma}= \left(\frac{V_2}{V_1}\right)^\gamma
AM
lol for some reason i thought something else was going on, thanks anyways:biggrin:
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
