BuddyBoy
				- 41
- 2
- Homework Statement
 - Evaluate if identical batteries in parallel draw the same current when connected with a conductor with resistance.
- Relevant Equations
 - V = IR
Theoretical thought experiment, trying to evaluate batteries in parallel, connected with non ideal conductors that have same current draw? Trying to understand the concepts here.
If I have three identical cells. Fully charged. Same age. Charged and discharged the same amount of times. Each cell has the same internal resistance ##r_{int}##. Lets say they are connected to a load that draws ##3 A##. I'm reading that each cell would draw the same current ##1 A##. Something like below:
Is this true though if I consider the resistance in the conductor? Say the top and bottom conductor are two separate identical conductors. The top conductor is a single nickel strip with width ##W##, thickness ##t## and length ##L##. This single nickel strip is placed across the positive poles of the three cells and to the load. Something similar is done for the negative poles. Consider that the distance between the first cell and the second, as well as the second and the third, is the same displacement. But the length between the third cell and the load is some other length. Now I can calculate the total resistance of the top conductor easily.
$$R = \frac{\rho\;L}{Wt}$$
Is it possible to calculate the values of R1 R2 and R3? If say for example I know that the cells are 3.7 V? I'm seeing some problems with assuming that each cell draws 1/3 of the current or 1A, like below.
The voltage at Node Z must be
$$3.7\;V - (1\;A)(r_{int})$$
But wouldn't this also be the voltage at node Y? If the nodes are at the same voltage, than there is no current flow between nodes Z and Y. So I'm wondering how do I model this circuit, and what I'm doing wrong exactly?
It seems like the non-ideal resistance has to be placed right before and after the load.
But I'm not understanding why exactly. The nickel strip connecting the first and second cells has some none zero resistance between these two points.
