Identical Springs: Stretching 0.160m with 50 Coils
  • Thread starter Thread starter jmccray
    Coils Springs
The discussion revolves around calculating the stretch of two identical springs after a 100-coil spring stretches 0.160 m under a load. To determine the stretch of each 50-coil spring, the spring constant must first be established. The original spring's stretch is related to its spring constant and the force applied. Once the spring constant is known, the stretch of each new spring can be calculated using the same force. The conversation emphasizes the importance of understanding the spring constant in solving the problem.
jmccray
An object is attached to the lower end of a 100-coil spring that is hanging from the ceiling. The spring stretches by 0.160 m. The spring is then cut into 2 identical springs of 50 coils each. Each spring is attached between the ceiling and the object. By how much does each spring stretch?
Could you please show your efforts thus far.
~H
all i have is a picture. I am unsure of how to even begin.
Try working out the spring constant first.
~H
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
