Identifying the material with a particular hardness
  • Thread starter Thread starter polka129
    Hardness Material
Identifying a material with a hardness of 240-260 HV can be challenging due to the variability in hardness values among different materials, particularly steel, which can vary based on composition and heat treatment. Visual inspection may help narrow down potential materials, but it often requires further testing for chemical composition or density to accurately identify the material. Since not all materials have a unique hardness value, multiple candidates may fit the measured hardness. Accurate identification is crucial for procuring the component to the desired dimensions. Comprehensive testing may be necessary to ensure the correct material is selected.
polka129
Hello ,
Pursuant to a relentless mugging into material data sheets,I am still unable to identify the material of a component corresponding to the hardness of which i measured using an ultrasonic equipment. its 240-260 HV(vickers).I need to know the material for procuring the component to the desired dimensions.
That's going to be tricky. Not all materials have a unique hardness value. Take steel, for instance. Depending on the particular composition and heat treatment, steel can take on many different hardness values. Sometimes you can narrow down the type of material by visual inspection. You may have to test it for chemical composition or density to narrow the list of possible candidates.
