If light hits a mirror and then switches direction
5 replies · 3K views
seerskater
if light hits a mirror and then switches direction...
if light hits a mirror at a 90 degree angle, wouldn't it HAVE to travel slower than the speed of light when it hit the mirror?
on Phys.org
HallsofIvy said:
When light reflects from a mirror, it is absorbed by the mirror and re-emited. It does not "stop" and change direction.
I meant more what hallsofivy guessed. That is interesting though. Would the angles of reflection the same for a solid object bouncing off a wall? it seems odd that light's angle of reflection wouldn't be jumbled around somehow while it was absorbed by the mirror.
Just a niggle, here. If light hits a conventional rear-surface silvered mirror it will travel slower than its normal speed in air when it hits the glass, until it is reflected by the silvering and re-exits the glass and re-enters air. This is not situation with a front-surface silvered mirror like those used in telescopes or the larger flat mirrors that are used to allow optometrists/ophthalmologists to test your visual acuity in small exam rooms. In such cases, the light is reflected right back into the air and does not have to traverse any glass.
